Model: Honda SFX 50
Year: 2003
Category: Scooter
Rating: 78 out of 100. Show full rating and compare with other bikes
Safety: See our safety campaign with the high safety rated bikes in this category.
Engine and transmission
Displacement: 49.00 ccm (2.99 cubic inches)
Engine type: Single cylinder
Stroke: 2
Power: 5.40 HP (3.9 kW)) @ 7000 RPM
Torque: 5.80 Nm (0.6 kgf-m or 4.3 ft.lbs) @ 6500 RPM
Bore x stroke: 39.0 x 41.4 mm (1.5 x 1.6 inches)
Gearbox: Automatic
Physical measures
Dry weight: 71.0 kg (156.5 pounds)
Seat height: 755 mm (29.7 inches) If adjustable, lowest setting.
Overall length: 1,720 mm (67.7 inches)
Overall width: 635 mm (25.0 inches)
Chassis and dimensions
Front tyre dimensions: 100/80-10
Rear tyre dimensions: 100/80-10 Front brakes: Single disc
Rear brakes: Expanding brake (drum brake)
Speed and acceleration
Power/weight ratio: 0.0761 HP/kg
Other specifications
Fuel capacity: 6.00 litres (1.59 gallons)
Min kones 2001 mod SFX har gått 15 000 km , skiftet variator ruller i den originale variatoren nå i vinter, og den er ikke slik du beskriver.
Moppen din går over 100 kmt ... jada
